I wonder, whether an equation
$$R = 2P + S$$
should give a geometrically sound design, where $R$ is the tooth count for the ring; $P$, for the planets; and $S$, for the sun.
I have tried to model a planetary gears with $R = 47$, $P = 16$ and $S = 15$. They do look well as for diameters, but the teeth do not match - it cannot be assembled.
Does the equation above guarantees, that the gears will fit each other? I now tend to think, that it does not take into account assemble-ability. Or perhaps I made a mistake somewhere.
Module is 0.9. Centre circle of planets was calculated as:
$$D = \frac{m(Z_1 + Z_2)}{2} = \frac{0.9(15 + 16)}{2} = 13.95$$
I double checked everything and didn't find any mistake yet.
EDIT
The gears should be precise, I used "Involute Gears" macro in FreeCAD, which should provide a proven correct gears. The carriage is based on precise fully constrained sketch and the parts are assembled in fully constrained assembly. Thus, there should be no imprecisions here.
Where I would look for possible mistake (but didn't findany) is the position of planets against outer ring and sun (calculated as shown above), imperfections of outer ring, which is produced as subtract shape of involute gear with 47 teeth from a disk. And starting rotations of the gears for assembly.
But what I'm thinking is, if it is even that easy. The outer ring has 47 teeth, which is a prime number (and selected on purpose, because correct gears should employ prime numbers and have to care about a common divider), meaning that one third (we have 3 planets) has 15,6 teeth. And that means, that if you set the carrier sou that it points into the middle of the tooth with one of it's points, the other two will be offset from a center of a tooth by 6/10 of a tooth. While in the same time, the Sun has 15 teeth which are perfectly dividable by 3 and we can have it set with all three i.e. gaps pointing in the direction of all three carrier lines. This is confirmed by creating three lines constrained at 120° and rotating with one (other two follow), I cannot find any position at which would each line point at the same place on a tooth.
Now, I'm thinking, that this prohibits same condition for every planet. Meaning this is not possible to assemble (as is). But perhaps I'm missing something; the pointed simulator does depict same configuration assembled, but then it's only infographics which could cheat...
So issue is still open.
EDIT 2
It is also good to point out what should be possible to assemble then. Well, one configuration which should work is $S = 15$, $P = 15$ and $R = 45$, but then it is a very bad design due to $S = $P (having the worst common divisor possible). Adding 3 to 5 I get 48, which won't fit the initial equation, but adding another 3 I get $S = 15$, $P = 18$ and $R = 51$ which doesn't seem to be that bad. The greatest common divisor of a Sun and Planet is 3, meaning sun will turn 5 times before the same tooth will meet same tooth on the other gear.
