I have currently been experimenting with a phase change material to absorb the heat given off by the condenser in a small refrigeration system (about 1/5 hp compressor) and while it does absorb a substantial amount, it often requires a huge volume of the phase change material (many many kilograms of the stuff) which is not practical due to the heat.
Is there any other alternatives that can absorb heat without a huge increase in weight?
