I'm looking to use an epoxy in a high-temp environment like 800C, and one that is optically transparent at 450nm (not below 90% transmission). But i'm having trouble finding one. It can be made of any material, as long as it can be cured in a mold.
$\begingroup$ Are you using the epoxy as just an edge sealant/adhesive or is the epoxy going to be some kind of surface/ window ? If the latter you should use a high temp glass, the technology for molding glass is well established. $\endgroup$– William HirdSep 24, 2018 at 23:49
$\begingroup$ What's the application? Perhaps there's another solution. $\endgroup$– FarrisMar 17 at 12:53
since cured epoxy is a carbon-based polymer, you will have a very hard time finding one that can stand 800C. Have you considered a sintered ceramic?
2$\begingroup$ Yeah, near-100% fully dense and optically transparent sintered ceramics have been around for ~40 years. Not used much but they do exist. $\endgroup$ Sep 25, 2018 at 7:25
$\begingroup$ I want to see some of this mythical material $\endgroup$– DKNguyenNov 17, 2021 at 14:54
$\begingroup$ A link to an example material would improve this answer. $\endgroup$– Eric SJul 16 at 1:30
You will need to go for glass and casting.
High temp silicones and epoxies don't go to 800 deg C and they are not clear anywhere near their high temperature variants. Closest I know is a murky clear "crystallized silicone" that goes to 900 deg F.
Ceramic "adhesives" are granular and won't be clear.
Molten glass and a mold are the closest for your optical and temperature needs. You might be able to get away with pressurizing and heating a powdered glass (aka a silica ceramic) to try and make it clear, but 90% optical transmission is pretty demanding to the point where something molten might be required.
