When I try to create a flat form of a archimedes screw using Solidworks it gives me a diameter different from what is calculated manually basically using a Pythagoras Theorem. Can anyone explain the reason as to what is used by any 3D Software in order to calculate the diameter and essentially what factors am I assuming when I calculate using the pythagoras theorem only.enter image description here
I tried to calculate a screw with pitch- 400mm, OD - 400mm and Id - 268mm
Using Pythagoras theorem gives me a OD - 430mm and ID - 297mm circle
whereas Solidworks gives a OD - 450mm and ID - 318mm circle.
10
  • $\begingroup$ I'm not familiar with these jargon, 'Id, OD, ...' could you please edited it up to a bit and please add at least a screenshot of your CAD showing us how you use smart dimension. $\endgroup$ Sep 12 '18 at 13:48
  • $\begingroup$ OD is outer diameter and ID is internal diameter... $\endgroup$
    Sep 12 '18 at 14:07
    $\begingroup$ if you could show your working with an appropriate diagram we may be able to help $\endgroup$
    – DrBwts
    Sep 12 '18 at 14:16
    $\begingroup$ i bet the software is just calculating a diffdrent thing than you think its calculating $\endgroup$
    – joojaa
    Sep 12 '18 at 14:46
    $\begingroup$ When you are using solidworks' sheet metal tools, you should specify the material as I believe it uses this information to help it generate the flat pattern, based on the deformation behaviour of the material. $\endgroup$ Sep 13 '18 at 17:14
A flat helix (helicoid) is a ruled surface, but it is not a developable surface. So you are going to have a flattening problem. Try using the middle fiber radius and compare the hand calc to the software and see if they aren't a lot closer.
