I am trying to model a test which has grips that can translate in X and Y directions, as well as rotate. I have been trying to model this using constraints and a reference point but have not been able to model a situation where the coupon is rotated and translated, using the top surface of the coupon as the surface being moved, the rotation is about the Z axis.Coupon
Any help would be appreciated!
  • $\begingroup$ To clarify, I would like that top surface to remain a straight line... but act as a boundary that can rotate and translate. $\endgroup$
    – user17189
    Aug 16, 2018 at 19:19
