I am trying to find out what type of hinge or mechanism is used in fold down car TV's. I need to buy one for a project I'm working on but dont know the name. See picture above.
    $\begingroup$ Consider looking for laptop lid hinges. These should be easier to obtain (as replacement parts for laptops) and likely display the same behavior. $\endgroup$
    – SF.
    Commented Aug 13, 2018 at 14:54
  • 3
    $\begingroup$ What is your project? Orientation, mass, number of electrical signals which must pass thru hinge, number of "hold angles" ? Please don't post how you want to solve, but what you want to solve. $\endgroup$ Commented Aug 13, 2018 at 19:33
These are not usually simple hinges - they are often designed with cams etc to give a specific movement - so are usually specific to the item.
Think of kitchen cupboard hinges - the simple ones are easy to replace, but some have extending movements so doors can move out to clear other doors...
You may find a hinge that does the movement you require and then you will need to re-manufacture it to cope with the load you will be applying...
    $\begingroup$ This particular one seems to be simple pin joint. Athough if it is machine actuated it probably really is a fourbar. But yeah eurohinges are typically sixbar mechanisms. $\endgroup$
    – joojaa
    Commented Dec 12, 2018 at 21:17
The hinge will be similar to the one for the laptop monitor.
You can search "hinge for LCD monitors" such as this page.
