I am using Bernoulli's equation in order to calculate a relative area between two points in a pipe. Problem is, based on the solution I have obtained, I end up with imaginary numbers and not sure what to make of this practically. Here is my math:
$$\begin{gather} P_1 + \dfrac{1}{2}\rho v_1^2 + \rho gh_1 = P_2 + \dfrac{1}{2}\rho v_2^2 + \rho gh_2 \\ v_1 A_1 = v_2 A_2 \\ \dfrac{A_1}{A_2} = \sqrt{\dfrac{v_2^2}{v_2^2+\dfrac{2}{\rho}\left(P_2-P_1\right)}} \end{gather}$$
I know my velocity at location 2, density, and pressures. I have no change in height so I got rid of third element in Bernoulli's equation. I am trying to obtain an area ratio between both points.
It is very possible in my model that I will have a low P2 and high P1 leading to a negative denominator and an imaginary solution. I feel like I am missing something practical or mathematical here that is simple but my mind has drawn a blank.
As a side note, I am assuming non-compressible airflow. Cannot assume laminar flow.
