Is it possible to calculate torque required to rotate wheel but weight of wheel is unknown?
  • $\begingroup$ A wheel will rotate just as long as you can overcome the friction of the system. So even a very low torque motor can get a well balaced wheel system to rotate, its just going to take a long time to accelerate the system. So no with this info alone you can not answer anything. Not that knowing the wheel geometry helps $\endgroup$ – joojaa Aug 10 '18 at 9:01
  • $\begingroup$ Better yet, (since you didn't specify), what torque is required to rotate the wheel about a non-axle axis, when the wheel is spinning? (gyroscopic torque) $\endgroup$ – Carl Witthoft Aug 10 '18 at 17:27
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
