i have a 300kg motorcycle with a 1630mm wheelbase. I have a lazy susan 1000kg bearing, which will be centrally mounted on the steel plate. what is the minimum thickness steel plate at 350mm wide i need in order to support the motorcycle with both wheels off the ground. I am only 5’ tall and need to keep the turntable as low as possible. I initially considered using wood but the thickness required would mean my short legs wouldn’t touch the ground! Thanks for the framework suggestions. I can maybe now combine steel and wood into the design to reduce height and weight. Thanks to all you very knowledgable engineers who have given me quite a bit to think about! I will post a photo when....or if, I manage to make a workable turntable.
  • $\begingroup$ Welcome to Engineering! This looks like a "homework question" (even if it isn't homework). In order for such questions to be answered in this site, we need you to add details describing the precise problem you're having. What have you tried to solve this yourself? Please edit your question to include this information. $\endgroup$
    – Wasabi
    Aug 5, 2018 at 23:33
  • $\begingroup$ A frame work will permit use of thinner steel like 1 mm, otherwise you will need relatively thick steel to reduce deflection. $\endgroup$ Aug 6, 2018 at 0:02
  • $\begingroup$ A frame is the way to go - think of the plates used when they do road repairs... $\endgroup$
    Aug 6, 2018 at 4:27
  • $\begingroup$ I think we're missing part of the picture. What is the purpose of the turntable? What other loads are relevant? $\endgroup$
    – mart
    Aug 26, 2020 at 6:42
A steel sheet that diameter which is reasonably stiff would be pretty thick.
The most efficient solution would be to constructs a frame to support in to steel angle or rectangular tube with a steel or plywood plate on top.
It would probably also be a good idea to put castors and screw jacks around the circumference to give it a bit more stability, reduce the bending loads on the bearings and give you a way to lock it in place. Having support at the edge as well as the middle will also make the whole thing a lot stiffer
You have to think of a positive lock-in mechanism for a bracket or support of some sort, depending on what angle of slant you want to present the bike or do you want to offer a kind of ballast counter weight suspended mechanism so the bike can be easily angled on the display for variety of perspectives.
Even at the most basic configuration you need to have a rough estimate of how the weight will be distributed between the jack and suspension and wheels.
As has been mentioned in other answers it would be better to have a light truss or some base under the plate to make it lighter. But the most important question is the entire tray and the lazy susan have to be strong enough to support both the weight and off-center loading and more importantly it is going to resist toppling ( overturning moment), even during the time of loading the bike on it!
Otherwise the thickness of the plate sounds right at about 1/8" to 3/16". We can approximate the design using steel column bas plate equations.
