I enjoy creating mechanical designs but I am not a trained mechanical engineer.
I have a technical issue with a joint design that needs to be permanently retained using a press (snap) fit. Any idea on the size and tolerances for these two 304 SS parts to be pressed together using an arbour press without permanent deformation of either part? I will use a little lithium grease to help with the press fitting which will also serve as general lubrication for the shock absorber joint.
