Assume that a gas obeys the following equation of state:
$\nu = {\frac{RT}{P}}-{\frac{a}{T}} + b$
Where $a , b $ are constant.
Derive an equation for the temperature at the Joule-Thompson inversion state.
My professor gave us the following hint:
$ T = {\frac{\mu_{JT}c_p + \nu}{\frac{\partial \nu}{\partial T}}} $
Where ${\frac{\partial \nu}{\partial T}} $ is held constant at P
My attempt at the solution starts here:
When I differentiate the equation of state wrt T, I get
$ {\frac{\partial \nu}{\partial T}} = {\frac{RT}{P}} + {\frac{a}{T^2}} $
Plugging this back into the equation for T leads to:
$ T = {\frac{\mu_{JT}c_p + \nu}{\frac{RT}{P}+{\frac{a}{T^2}}}} $
Is this the correct approach to take to solve for the temperature at the Joule - Thompson inversion state? It seems I have need to take a cubic root for the temperature so I was not sure if this is what the intended answer is.
  • $\begingroup$ How do we know what the professor has decided? $\endgroup$ – Solar Mike Jul 25 '18 at 5:36
  • $\begingroup$ Hi @SolarMike, do you mind explaining your question a bit more? $\endgroup$ – ganondorf29 Jul 27 '18 at 14:44
  • $\begingroup$ Why don't you explain the "intended answer"... $\endgroup$ – Solar Mike Jul 27 '18 at 14:46
  • $\begingroup$ When you attempt to solve the equation for T, you get an analytical solution that I couldn't analytically solve without help of a computer (at least the answer per WolframAlpha). In addition, we did not discuss using numerical methods to solve for non-linear equations so I did not expect this answer. $\endgroup$ – ganondorf29 Jul 28 '18 at 20:25
