I want to calculate drag force at special angle on a sphere . There are some grooves on the sphere and these groove have a special angle on the sphere. In other words, I want to calculate drag force on the these grooves. How can I do it in Fluent?
I believe under Results>Reports>Forces, you can calculate the force on a chosen surface in a particular direction vector (by providing x,y,z coordinates). Does that help?
9
  • $\begingroup$ Thanks, but how can I provide x,y,z coordinates in Fluent? Please see y-z coordinate in above picture. Therefore, direction vector is as follows: y----> -cos teta and z---->-sin teta and x---->0 .........teta=angle Is it OK? $\endgroup$
    – user19061
    Commented Jul 25, 2018 at 19:36
  • $\begingroup$ Direction of flow is in direction (or parallel) of grooves. please see second picture in above $\endgroup$
    – user19061
    Commented Jul 25, 2018 at 20:00
    $\begingroup$ @user19061 in the 'Force Reports' dialog box, you input what direction vector you want to calculate, then Fluent will give you the total resultant force vector, as well as the force on the chosen surface in the direction vector you specified. $\endgroup$
    – Time4Tea
    Commented Jul 25, 2018 at 21:13
    $\begingroup$ @user19061 however, it might help if you could clarify further about the flow situation. Is this a full 3D model of a grooved sphere, with flow coming from the positive z direction? If so, for example, it might better to request the torque acting on the whole sphere, and the drag force acting on it. $\endgroup$
    – Time4Tea
    Commented Jul 25, 2018 at 21:16
    $\begingroup$ So, this isn't just 2 grooves, but a series of grooves, equally-spaced around the circumference of the sphere? In that case, the angle of the groove faces will be different for each groove and, furthermore, the groove faces may not be planar, which might further complicate the situation. $\endgroup$
    – Time4Tea
    Commented Jul 27, 2018 at 13:25
