I'm looking to conduct water level monitoring in streams and rivers for water resource engineering purposes. My plan is to use Arduinos and Raspberry Pis in conjunction with a pressure transducer, as Pis and Arduinos work with the telemetry system and water quality sensors that I have chosen for the project.
However, the standards in British Columbia, Canada (where I work) require that the sensor must have a 2 mm accuracy to collect "Grade A" data. Grade B data requires 5 mm accuracy, and as it turns out a pressure transducer with these accuracies are hard to find unless you spend >$500 per pressure transducer.
Does anyone know if a low cost ($300 max, but preferably $50 to $150) pressure transducer designed for measuring water with 2 mm or 5 mm accuracy exist? I'm also open to other technologies as well.
Thanks!
Page 4 in the attached in BC's standards doccument is attached if anyone is interested in checking it out.
    $\begingroup$ Welcome to Engineering! This looks like a resource-hunting question. Such questions are prone to becoming out-dated, and are therefore considered off-topic for this site. $\endgroup$
    – Wasabi
    Jul 19, 2018 at 22:15
  • $\begingroup$ Does it have to be a pressure transducer, or would some other mechanism be OK? $\endgroup$ Jul 19, 2018 at 22:28
    $\begingroup$ I've been looking at other instruments such as ultrasonics. We actually purchased a MB7369 HRXL-MaxSonar-WRM (link below), but ultrasonics come with some qualities that make them less desirable than pressure transducers when measuring a fluctuating water level such as the case with fast flowing streams. $\endgroup$
    – Rory G
    Jul 19, 2018 at 23:24
  • $\begingroup$ maxbotix.com/Ultrasonic_Sensors/MB7369.htm $\endgroup$
    – Rory G
    $\begingroup$ I would vote to reopen this if it were rephrased as "what is a cost effective type of instrument for measuring water levels to 2 or 5mm accuracy?", although I admit I recognize I'm not in majority on my opinion about the on-topic-ness of these questions. I'm curious though, what does it even mean to measure a river height to 2mm? The water level certainly varies more than that across its profile! $\endgroup$
    – ericksonla
    Jul 21, 2018 at 20:50
