Image 1 - what type of nut it is? what tool I have to use to open it?
Image2 - what type of lock it is? what tool I have to use to open it?
Please see the two images. I marked a nut and locking part. what type of nut and lock mechanism it is? and what is the tool I have to use to open it?
You need to hold the shaft (in a vise with protective jaws) and turn that nut with a "C" spanner - which looks like a C with a single protruding tooth.
A poor method is to use a drift or punch, but this always damages the nut - perhaps fine for a temporary repair...
Edit as Fred says that is a circlip, actually in internal circlip which means that the nut above needs to be removed first then that circlip will come out.
  • $\begingroup$ Thanks. What is that other part that I marked in the second image? what the name of that nut? $\endgroup$
    – Aayvu.com
    Jul 8, 2018 at 9:16
  • $\begingroup$ Called C nuts... as for the other pic - need more detail - may just be the face edge of a clamping nut for the bearing... $\endgroup$
    Jul 8, 2018 at 9:19
  • $\begingroup$ The second photo shows a circlip, the size of which I've never seen before, but is clearly that type of retainer. $\endgroup$
    – fred_dot_u
    Jul 8, 2018 at 10:41
  • $\begingroup$ Sometimes also called a collet wrench and collet nut, due to one of their more common uses. $\endgroup$
    – Phil Sweet
    Jul 8, 2018 at 12:56
