In wind turbine, Is the number of revolution taken in 1s is called 1P frequency? If not, is it possible to find the 1P rpm from rpm measured for 1 hour (that is, I have 60 rpm data points from tachometer)?
  • $\begingroup$ You are mixing up your units. RPM per hour makes no sense. Do you mean revolutions per hour? Edit required. $\endgroup$
    – Transistor
    Jul 7, 2018 at 18:00
    $\begingroup$ I meant I have measured rpm every minute for an hour. That is, I have 60 rpm data points $\endgroup$
    – Selva
    Jul 7, 2018 at 18:15
The constant rotational speed is the first excitation frequency, mostly referred to as 1P. The second excitation frequency is the rotor blade passing frequency: NbP in which Nb is the number of rotor blades: 2P for a turbine equipped with two rotor blades, 3P for a three bladed rotor.
source: https://ocw.tudelft.nl/wp-content/uploads/Soft_soft___Berlijn_2002.pdf
In wind turbine, is the number of revolution taken in 1 s is called 1P frequency?
According to Dynamics of offshore wind turbines supported on two foundations you are correct.
Average the RPM readings and divide by 60 (seconds in one minute).
Disclaimer: I looked up the first part. I am an EE but never heard of 1P before.
