I need to measure the width of a bar made out of glowing red steel (900-1200 degrees Celsius) using computer vision.
In order to ensure resolution of a 0.5 millimeters/px, the camera is needed to have enough pixels and, considering the field-of-view, to be at a certain distance from the bar.
Can anybody think of a way to use a camera at a distance of 0.5m from the glowing hot bar? Air refrigeration? Refractory enclosure?
Let's talk about it?
    $\begingroup$ Are you sure its just not cheaper and more accurate to get a telecentric lens and put it further? Also seems to me that you have made a premature decission for method used $\endgroup$
    – joojaa
    Commented Jul 5, 2018 at 5:33
    $\begingroup$ Insulated enclosure with fireproof glass window, air-cooled. Additional bonus: easy to install a dim filter to reduce glare from the glowing steel, which is bound to confuse the camera. $\endgroup$
    – SF.
    Commented Jul 5, 2018 at 8:13
  • $\begingroup$ Use the glass used in welding goggles - some are available as flat sheets about 2.5" by 4"... $\endgroup$
    Commented Jul 5, 2018 at 8:28
  • $\begingroup$ thank you all for the replies. @joojaa , the computer vision method was chosen before i had my hands on the project. As an engineer I just gotta make it work. Excelent tip about the telecentric lens, though. I will do some research about the application. Thank you very much for the reply. $\endgroup$ Commented Jul 5, 2018 at 16:28
    $\begingroup$ Yeah but why the spcific camera $\endgroup$
    – joojaa
    Commented Jul 5, 2018 at 16:33
Do you need a single camera, or could you build a precision mount with 2 smaller cameras, each covering one end of the bar? Saves you a ton of pixels. Or, for that matter, a single camera with an external set of path-folding mirrors & prisms so that what the camera "sees" is just the ends of the bars. This is a common approach taken in various laboratory work when only two small non-adjacent regions are of interest.
