I am trying to make this Goal
I was able to make the base feature but I am facing problems with the secondary features. So could anyone shed some light on how to make the datum planes on cones.
I made one feature using this Plane as was instructed from where I am learning. However, I am unable to make the plane for the other feature.
So far I have made this Model
Thanks in advance
    $\begingroup$ The images are not loading for me - can you check this? $\endgroup$ – Jonathan R Swift Jul 2 '18 at 9:54
  • $\begingroup$ @JonathanRSwift Sorry for inconvenience. I have done that now. $\endgroup$ – Ammar Qazi Jul 2 '18 at 10:04
  • $\begingroup$ You can make a plane or projected line from the top and then make a plane either tangent to plane and cone surface or tangent to cone and on line. This allows you to easily change the angle after the fact. Sorry im in a hurry i might write this as an ansver later. $\endgroup$ – joojaa Jul 2 '18 at 12:01
You dont actually need a datum plane, you can do it with a revolve. But yes you can do this much more easily than you think.
  1. When creating a plane click on he cone surface quilt, then change the option from Through to Tangent. Yeah the GUI is a bit sleazy the option is a drop down even if it has no affordance. Bad UX designer!
  2. Then add another constraint and choose a plane or line that defines the rotation around the central axis.
  3. And finally
Also note extrusions can define different extrusion values to both directions so no need to create the second set of planes offset (or the extra axes for that matter). Personally I would make the planes internal to the feature creation as it clutters my view and model tree less.
  • $\begingroup$ Thanks a lot for your input. I found another workaround and managed to make the model. But I had to draw it with model upside down. Your method is much more suitable as the sketch environment remains normal. It would really come handy. $\endgroup$ – Ammar Qazi Jul 3 '18 at 16:14
