I am thinking to develop a remote-sensing applications for vehicle pollutions. In such cases generally expensive optical IR and UV devices are used because more precise. These devices are generally ready-to-use and have also a graphical interfaces and other commands plus all the algorithms already implemented while I am interested only in the sensor part of such devices.
On the contrary electrochemical gas sensors are cheaper but much less precise. Generally these sensors have a response time from 20 to 60 seconds.
Suppose I can use a less precise estimate: can environmental polluting gas (electrochemical) sensors detect emissions of a low speed passing vehicle in a semi-closed environment such as a garage to have an approximate estimation?
My biggest fear is that these sensors are too slow to detect anything, even for a low-speed vehicle in load conditions.
Alternatively do you now any optical IR/UV open-path emitter/receiver sensor to analyze polluting gases from vehicle emissions and whose (electrical) output can be analyzed by embedded devices such as microcontrollers or micro-computers?
EDIT: The pollution gases due to road vehicles are typically CO, NO, NO2 but also CO2 should be monitored. These are the gases maybe with more concern but also SO2 might be important. The goal is to have an estimate on how much each vehicle is polluting: this estimate is not precise but it becomes important having large enough data to see for example which brand is most polluting. This is an example of device but it is used for industrial applications.
EDIT2 Let me reply to Bart's answer because it seems to me that the topic is not really clear here.
This has already being done (from late 80s-early 90s) using NDIR and UV. You do not measure the concentration directly but rather the ratio between a pollutant and CO2 because it is assumed to remain constant with the gases dispersion (so the wind effect should be minimized).
The idea is not to get a single precise costly and time-requiring measurement but to get many cheap less precise fast measurements. In this way it is possible to guess for example which brand or model is more polluting, and also to guess if a vehicle is polluting too much. With on-board expensive tests you confirm or reject those results.
From the analysis of emissions using extra data such as model/brand, category diesel or not you can provide also other estimations.
  • $\begingroup$ I am not aware of any Optical IR/UV sensors that are capable of detecting polluting Gas. Which of the pollutant gas are looking to detect? Is you goal to identify which vehicles are polluting or just detect pollutants. Is it important to identify the vehicle with that is contributing to pollution? The following post briefly discuss the working of electrochemical sensors MQ3 Alcohol sensor $\endgroup$ Commented Jul 1, 2018 at 10:27
  • $\begingroup$ Please look at the edit $\endgroup$ Commented Jul 2, 2018 at 8:06
It's very inaccurate to measure for emissions of a vehicle passing by, in a non hermetically closed environment. The slightest breeze will make the measurements incoherent. Depending on the sensor and type of emission, you may not even detect it. Ideally, you measure in the exhaust of the vehicle, which can be considered a closed environment. For emission tests, they accumulate exhaust gases in 'bags' and then measure them, either accurately diluted with air or not. Constant volume flow systems are also used. Google for them to get an idea.
Regarding emissions, most electrochemical sensors are inferior to NDIR sensors, and most of them get consumed by measuring. They have limited shelf and usage life, and measurements can be spoiled by cross interfering gases. For instance, a CO sensor may see CO2 as CO, and thus reports a higher CO concentration than in reality. This also happens with NDIR sensors though. Using them directly in the exhaust gives them a too concentrated sample, and they'll get contaminated with sooth very quickly. So find a way to dilute the exhaust gas.
Sulphur based emissions are barely present, and thus hard to detect. NOx is also rather hard to detect, HC and CO are easily detected, CO2 is really easily detected because of it's abundance in exhaust gas.(roughly 15%) I'd recommend you to look into the typical emission concentrations in exhaust gas. It may give you a better idea about what and how to measure.
If you want to compare various fuels or vehicles, make sure they're operating in the exact same way, so the fuel or vehicle is the only thing that makes the difference. Otherwise the tests are meaningless.
  • $\begingroup$ What you are saying is imprecise, has already being done (from late 80s-early 90s) using NDIR and UV. You do not measure the concentration directly but rather the ratio between a pollutant and CO2 because it is assumed to remain constant with the gases dispersion. The idea is not to get a single precise (costly) measurement but to get many cheap (less precise) measurements. In this way it is possible to guess for example which brand is more polluting, which model it is and also to guess if a vehicle is polluting to much. With on-board expensive tests you confirm or reject those results. $\endgroup$ Commented Jul 3, 2018 at 9:26
  • $\begingroup$ @FrancescoBoi Official CVS is used afaik, non-official tests may still use the bag system, where i worked and our competitors did. Probably because of costs. I do recommend NDIR sensors though. I don't get why'd you use CO2 as a reference. You can't assume that other emissions are proportional with increase of CO2 measured in the room. But maybe i misunderstand you here. Anyway, i don't think you'll have sensible results in a non enclosed space with a vehicle passing by. There's just too many parameters that can change, and have influence on the measurements. Taking lots of 'em won't make up $\endgroup$
    – Bart
    Commented Jul 3, 2018 at 19:37
  • $\begingroup$ For the CO2 probably they assume the rate of dispersion is the same of other gases. Here there is a list of papers about the topic. You can get an idea since I could not explain better.feat.biochem.du.edu/pub_list.shtml $\endgroup$ Commented Jul 5, 2018 at 13:34
  • $\begingroup$ @FrancescoBoi I see, that is still a relatively safe assumption, but the proportions of emissions are not always the same, not even nearly. So measuring a certain amount of CO2 doesn't give any info about eg. CO. CO2 may say something about the amount of fuel used, but nothing about how 'dirty' an engine runs. So potential dieselgate like scandals won't be detected that way, i suppose. Measuring for NOx would make more sense then. $\endgroup$
    – Bart
    Commented Jul 6, 2018 at 17:37
  • $\begingroup$ Again, you are measuring both: CO2 and the pollutant, you are not deriving one from other. $\endgroup$ Commented Jul 7, 2018 at 6:43
