Do Oxygen lambda sensors (used in automotive applications) work in trace gas environments?
My requirements for a trace Oxygen gas sensor:
  1. The sensor must be capable of working in an inert gas environment of either Nitrogen or Argon.
  2. The sensor's operating temperature is not more than 40-50 degrees Celsius.
  3. The sensor is capable of sensing an Oxygen gas concentration as low as 10 ppm to an Oxygen gas concentration as high as (19-25%, that is, an Oxygen concentration of regular air).
Could anybody who is working with such sensors suggest some sensor that I can use in such environments?
  • $\begingroup$ Why not get the data sheets for the sensors you are looking at? That will tell you the sensitivty etc... $\endgroup$ – Solar Mike Jun 27 '18 at 7:10
  • $\begingroup$ @SolarMike I have the data sheets of electrochemical sensors that I can use for such environments. But i don't know where to start for lambda sensors. Also, whenever I looked up trace gas sensors, electrochemical sensors were always mentioned. Lambda sensors were never mentioned. $\endgroup$ – athindra pavan Jun 27 '18 at 7:24
  • $\begingroup$ Do you think lambda sensor is the name given to the electrochemical sensor in the auto industry as that is the function it is used for? $\endgroup$ – Solar Mike Jun 27 '18 at 7:26
  • $\begingroup$ @SolarMike According to Wikipedia, lambda sensors are electrochemical sensors. However, the construction of the sensor is significantly different from that of the trace gas sensors (like Figaro's KE25) that I have looked up. Also, the reason why I'm asking this question is the fact that automotive applications don't deal with trace gas environments. $\endgroup$ – athindra pavan Jun 27 '18 at 7:36
  • $\begingroup$ You are concerned about what the sensor is capable of, not how it is used in a car or the package it comes in... $\endgroup$ – Solar Mike Jun 27 '18 at 7:39
