I am a novice who is trying to make some gears. I have followed the formula's but sadly something seems to go wrong and the gear's don't come out right. Below is some dimensions and pictures.
Gear 1
- Module(Diametral Pitch)(P) = 3,
Teeth(N) = 12,
Pitch Diameter(PD) = 36,
Addendum(A) = MODULE = 3,
Deddendum(B) = 32.529,
Outside Diameter(OD) = 39,
Root Diameter(RD) = 28.5,
Base Circle(BC) = 33.82884,
Circular Pitch (CP) = 9.4248,
This produces a gear that looks "right" (small gear on right) here is a link to my CAD file https://cad.onshape.com/documents/e67e4eedf7e94a76c439bef0/w/4a5cb0732a0c5ca585fb5d87/e/2a98076fc77593239bb0eaa7
Now when i apply the same formula's to gear 2 i get a issue.
Gear 2
Teeth(N) = 40,
Pitch Diameter(PD) = 120,
Deddendum(B) = 116.529,
Outside Diameter(OD) = 123,
Root Diameter(RD) = 112.5
Base Circle(BC) = 112.7628,
Pressure Angle = 20 (for both gears)
Here is link to the CAD file https://cad.onshape.com/documents/e67e4eedf7e94a76c439bef0/w/4a5cb0732a0c5ca585fb5d87/e/2a98076fc77593239bb0eaa7
The base circle and root diameter are practically the same ?!
The gear teeth look different but i have used the same formula's for both gears.
Here are the formula's i have used, just in case there is a massive error!!!!
- Module(Diametral Pitch)(P) = 3 (Saw this number used so stuck with it!)
Teeth(N) = 40, (Wanted to try a bigger number)
Pitch Diameter(PD) = 120, (Teeth x Module) (40 X 3)
Addendum(A) = MODULE = 3, (I hope this is true !)
Deddendum(B) = 116.529, (1.157 x P(Module) = 1.157 x 3 = 3.471 =120 - 3.471 )
Outside Diameter(OD) = 123, (Pitch diameter + Addendum)
Root Diameter(RD) = 112.5 (Pitch Diameter - (2.5 X Module) = 120 - 7.5)
Base Circle(BC) = 112.7628, (Pitch Diameter x COS (20pressure angle)
Circular Pitch (CP) = 9.4248, (PI x Module)
Here are some pictures
The diameters you can see on the pictures are in order from the top of the tooth to the centre:
Outside diameter, Pitch circle(pitch diameter), Base circle, Root diameter,
The images show the bigger gear with its base circle and root diameter practically on the same diameter. The smaller gear seems more in proportion
I set the Module(diametral pitch), which in this case is 3. I only used this number because I saw it used in a example Involving 12 and 24 teeth gears.
Does anyone think I should have change it as one gear is quite big (gear 1 is 12 teeth and gear 2 is 40 teeth) or is it just personally preference?
Did I use the module of 3 incorrectly for these gears?
I sadly forgot to mention in the original question the centre distance between the gears, which is 78mm. I am not sure if you would set the module (diametral pitch) based on the centre distance.
