8
A study from Purdue University suggests the Moon contains a number of wide underground lava tubes, up to 5000 m wide and about 1500 m high, in which subterranean cities could be constructed. Such tubes would protect potential residents from cosmic radiation and from the extremes of temperature on the surface.
Prior to constructing anything in such tubes the inside of the lava tubes would need to be inspected for integrity of the rock and where localized weaknesses were found these would need to be fixed. The risk of a rock or a wedge of rock dislodging from the backs/roof/ceiling or walls of the tube and falling on people, plant, equipment or buildings would need to be to mitigated.
What would be the best way to stabilize any local weak spots in the internal surface of the lava tubes?
For example, here are some common tools and techniques for adding stability to natural and engineered structures:
  • Tensioned cable bolts
  • Rock bolts
  • Shotcrete
  • Shotcrete, steel mesh and bolts
  • Concrete lining via form work, as opposed to shotcrete
  • Polymer coatings
  • Ceramic coatings
  • $\begingroup$ If something was on the verge of falling, why wouldn't you just make it fall right away, before you build a city under it? $\endgroup$
    – Dave Tweed
    Mar 25, 2015 at 14:16
    $\begingroup$ @DaveTweed: True, but a rough spot will result from the fall site which would need to be sealed. Anything falling from a height of 1000 - 1500 m would do damage to whatever it hit, even a small rock. If the fall site is was not sealed, further unravelling of rock could occur, creating an even bigger problem. $\endgroup$
    – Fred
    Mar 25, 2015 at 14:34
  • $\begingroup$ Wouldn't the cave need to be sealed so that it could be pressurised? Then the concern wouldn't really be something falling in, but blowing out. I think a transparent polymer would be cool, not sure how we will get it up there though. $\endgroup$
    – jhabbott
    Mar 25, 2015 at 17:47
  • $\begingroup$ @jhabbott: Good point about possible pressurization. It would facilitate the mobility of people living there. Maybe part of the answer is to construct domes within the tubes which could be pressurized & might offer some protection against rockfalls. As I said in my comment to Dave Tweed, anything falling from 1000 m + will do a lot damage, even in the 1/3 g of the Moon. Reducing the risk of rockfalls would still be a priority. As someone who has been involved in underground infrastructure I know that maintaining the integrity of the surface of an underground opening is key to stability $\endgroup$
    – Fred
    Mar 26, 2015 at 0:52
The natural way to stabilize it is to pressurize it. The normal atmospheric pressure is ~ 100 kPa. To do that a gigantic air-tight liner should be inserted within the lava tube. It would be a little larger than cavern on order to transfer pressure loads to rock walls and sealing. A tricky equilibrium must be designed between gravitational induced rock pressure and internal gas pressure. It is a challenging engineering task but looks more realistic than large scale engineering works the under lunar surface.
As a benefit, this solution will provide a large habitable space.
A precedent exists in terrestrial engineering practice during the construction of subway tunnels under the river bed.
The picture provided by question shows very 'artificial' cross-section. The beautiful FEA analysis may be repeated with more realistic cross-section and internal pressure included.
terrestrial lava tube
Terrestrial lava tube crossection. The flat floor of some lava tubes is usually a result of later sediments.
  • $\begingroup$ The envelope can be split into multiple isolated sections with airlocks between them. $\endgroup$ Jun 16, 2015 at 20:42
