Given a triangle with nodes 0, 1, and 2 where each node is located at $r_i = x_i,y_i,z_i$ for $i = 0:2$ and has an associated scalar value $\phi_i$ at the node, how would I evaluate the directional derivative $\nabla_u \phi$ at the centroid of the triangle at the centroid of the triangular element given the direction $u$.
I've figured out how to evaluate $\nabla_u \phi$ on each edge separately but not sure how to get the value at the centroid.
    $\begingroup$ If its a lagrange element, then the solution is linear inside each triangle. The gradient of a linear function is constant. The gradient at the edges is not unique since FEM computes a piecewise linear solution in each element. How did you compute the edge gradients? $\endgroup$
    – Paul
    May 30, 2018 at 5:05
  • $\begingroup$ I just used the values at each node over the distance between the nodes for the edges: $(\phi_1 - \phi_0) / (r_1 - r_0)$ $\endgroup$
    – nrabbit
    May 30, 2018 at 16:00
  • $\begingroup$ Use Barycentric coordinates. $\endgroup$
    – joojaa
    Oct 31, 2018 at 15:31
The easiest way is to fit a linear function a + b x + c y. To find a, b and c solve the system of equations:
a + bx0 + cy0 = phi0 a + bx1 + cy1 = phi1 a + bx2 + cy2 = phi2
If (u1,u2) is the unit vector in the direction u, the the directional derivative is: bu1 + cu2
  • $\begingroup$ Thats by intuition. Not a numerical method $\endgroup$
    – Fennekin
    Jun 3, 2018 at 11:33
