I am wondering if there is a procedure to verify that the constraints of a system of rigid bodies are independent.
Here there is an example of a system with dependent constraints: L beam - Strange result
Thank you for your willingness.
Sign up to join this communityI am wondering if there is a procedure to verify that the constraints of a system of rigid bodies are independent.
