I have been recommended not to run the two-wheeler (Suzuki Access) at a constant speed (I give a constant throttle in a way that I run essentially at a constant speed of about 40-45 kmph). In fact, I have been told to keep changing the acceleration (smoothly though) for lesser fuel consumption. I want to understand the technical reason behind this claim.
  • $\begingroup$ (1) What is a Suzuki Access? Is it a petrol engined motor bike? (2) Your post seems to mix up speed and acceleration. Can you edit your post to clarify exactly what you are asking? $\endgroup$ – Transistor May 19 '18 at 12:39
  • $\begingroup$ I think he's more likely mixing up 'acceleration' and 'the position of the accelerator (throttle)'? $\endgroup$ – Jonathan R Swift May 19 '18 at 20:57
  • $\begingroup$ @Transistor Suzuki Access is a scooter running on petrol $\endgroup$ – user16060 May 20 '18 at 7:03
  • $\begingroup$ @JonathanRSwift Thanks for pointing out. I realize that 'the position of the accelerator (throttle)' makes more sense than writing 'acceleration'. $\endgroup$ – user16060 May 20 '18 at 7:04
Your question doesn't make much sense.
  • For a given set of conditions - selected gear, gradient, load, wind and road resistance - there is a required power to maintain constant speed.
  • Since power is a function of throttle position and this increases with throttle rotation then there must be only one throttle position that generates that power.
The graph and topic is discussed further in https://physics.stackexchange.com/questions/57888/why-does-higher-acceleration-minimize-a-cars-fuel-consumption.
The optimum speed for obtaining maximum efficiency varies is not a constant with the load. That might be the reason for the advice.
