this is deblistering machine by Stripfoil. I wounder to know the mechanism of blades movement ( equally ) with one? screw. when the operator rotates the handle, all blades move with the same distance.
    $\begingroup$ A set of cams...? $\endgroup$ – Solar Mike May 15 '18 at 12:36
One way to achieve this is by a series of 4 bar linkages
The above is used for marking out equally spaced points on a line of arbitrary length.
Pretty simple and elegant. By virtue of the geometry you can choose any two points as the start and end and the distance between them will always be equal fractions of the total.
Obviously in this particular context you would need some extra parts to implement it properly and maybe make the whole thing a bit stiffer, but within reasonable range of adjustment it should do exactly what you are looking for.
  • $\begingroup$ We have a winner. Almost assuredly the right answer. $\endgroup$ – Eric S May 15 '18 at 14:26
  • $\begingroup$ @EricShain of course it is. $\endgroup$ – Mironline May 15 '18 at 16:04
  • $\begingroup$ Its probably a variant of this though where the bottom links are replaced by a slider. $\endgroup$ – joojaa May 15 '18 at 17:32
