I have an electronic assembly and part of what it does is to measure and report temperature. The electronics are housed is a plastic enclosure, and there is a small fan blowing out of the enclosure. There are also intake openings in the enclosure wall.
It's a simple fact that the temperature inside the enclosure is above ambient temperature seeing as the electronics itself is a heat source and the enclosure naturally has thermal insulating properties.
That being said I want to report ambient temperature without my temperature sensor being outside the enclosure, and I'm willing to perform a calibration step to get there.
The questions are, (1) is it sufficient to model the transform as a simple offset? (2) What tools can I use to understand the relationship between the internal and external temperature in my enclosure, over a range of external temperatures? (3) What are the most important variables I need to control in order for my calibration to hold in practice?
It's not clear why you wouldn't put the temperature sensor close to one of the points where outside air is drawn in and shield it from the inside temperature. However, ...
Provided the power dissipated in the box (or the energy consumed inside the box) is constant then the temperature rise, $ \Delta T $ of the inside relative to the outside will be governed by the thermal resistance of the box inside to outside. This would be analogous to Ohm's law, $ V = IR $ but now we have $ \Delta T = QR $ where Q is the heat flow and R is the thermal resistance which in your case should be a constant.
If power consumed inside the box is not a constant then Q will vary so you would have to measure power consumption and correct for that.
For a simple system a fixed offset should work and it should be possible to verify with a pair of probes or sensors such as the LM35 which give 10 mV/°C output and, so, can be measured using a decent multimeter.
  • $\begingroup$ How much would you expect enclosure orientation to influence the temperature offset? How about the nature of the exhaust port (e.g. from above or below) and the nature of the surface (e.g. porosity, material type) in proximity to that exhaust port? $\endgroup$
    – vicatcu
    May 6 '18 at 21:34
  • $\begingroup$ Hot air rises, so I'd expect it to influence the offset. Note that you are adding details (portable / handheld device?) that are missing from your question. This is not good. $\endgroup$
    – Transistor
    May 6 '18 at 21:37
  • $\begingroup$ You are right, I worried about introducing a bias and leading answers, and I'm outside my domain of expertise. It's not handheld / portable. It resides in a stand and is wall powered, so orientation should be fixed and it's a continuous monitoring application so power consumed should be relatively constant. $\endgroup$
    – vicatcu
    May 6 '18 at 21:38
