11
Localities in the US have different road layout and setups.
For example the Michigan Left, Jersey Left/Jug Handle, vs a standard 4 way stop with left turns at the intersection.
Have any of them come out as clear winners?
  • 3
    $\begingroup$ Your question might attract more answers if you narrow the field to either highways or regular roads. I believe the characteristics (and answers) are different between the two. $\endgroup$ – user16 Jan 24 '15 at 16:47
    $\begingroup$ @JedF, This a great question, I am familiar with both MI and NJ. Can you improve the question? On Problem in NJ is the Jug handle is too short, and creates problem. Other problem is the Jug handle is too confusing and complicated $\endgroup$ – Mahendra Gunawardena Jan 24 '15 at 16:50
  • $\begingroup$ @GlenH7: Any intersection where cars have regular occurrence of crossing paths. For example the diverging diamonds I have seen have all been used as offramps. So it would technically include both a highway and regular road. $\endgroup$ – JedF Jan 26 '15 at 18:57
  • $\begingroup$ @MahendraGunawardena: When compared to a regular 4 way stop with out MI or NJ left do MI or NJ lefts increase, decrease or leave the same the number of accidents and accident severity? $\endgroup$ – JedF Jan 26 '15 at 18:58
9
Yes.
Michigan left
This page (pdf here) is very informative, though you really have to dig to get what you want. In a sub-section of 10.2.2 Median U-Turn Crossover, I found this (A "Michigan left" is referred to as a "median U-turn crossover"):
A study on a Michigan corridor used simulation to compare median U-turn crossovers with two-way left-turn lanes (TWLTL). The study showed that during peak hours, the corridor with median U-turn crossovers had a lower travel time by 17 percent and a 25 percent higher average speed than the same corridor with a TWLTL. However, vehicles made more stops on the arterial with median U-turn crossovers. In nonpeak hours, the median U-turn crossovers had the same efficiency as the TWLTL, even though a higher delay for left-turning vehicles had been expected due to the higher travel distance a vehicle must cover to turn left using a median crossover.
So that's a yes for stopping congestion during peak hours. More information on that specific simulation can be found under found under footnote 149, which isn't too easy to find. Other simulations reportedly found similar results:
Simulation studies using a range of intersection configurations (number of through lanes on the major and minor street) and volumes from intersections in Virginia and North Carolina suggest a reduction in overall travel time for all movements through the intersection when compared to a conventional intersection: -21 to -2 percent during off-peak conditions, and -21 to +6 percent during peak conditions. The studies also show a general increase in the overall percent of stops when compared to a conventional intersection: -20 to +76 percent during off-peak conditions, and -2 to +30 percent during peak conditions.
The rest of 10.2.2 has some more safety information:
  • The collision rate is lowered slightly
  • There are less "conflict points" (i.e locations where collisions are likely to happen)
Jersey jughandle
The Jersey jughandle (referred to as simply a "Jughandle") does reduce conflict points, though not as much as a Michigan left. It, too, appears to increase efficiency:
Simulation studies using a range of intersection configurations (number of through lanes on the major and minor street) and volumes from intersections in Virginia and North Carolina suggest a reduction in overall travel time through the intersection when compared to a conventional intersection: -6 to +51 percent during off-peak conditions, and +4 to +45 percent during peak conditions. The studies also show a large increase in the overall percent of stops when compared to a conventional intersection: +15 to +193 percent during off-peak conditions, and +19 to +108 percent during peak conditions.
Is there a clear winner? Both clearly reduce travel time and congestion, so the answer to your question is a definite yes. The Michigan left has many less conflict points (16) than the Jersey Jughandle (26), which I consider quite the advantage (the standard four-way intersection has 32). It also has a lesser increase in stops. I'd give the edge here to the Michigan left, though both are probably improvements over your standard four-way intersection.
| improve this answer | |
  • $\begingroup$ @HDE226868: If that is the case why has it not been widely adopted outside of Michigan? $\endgroup$ – JedF Jan 28 '15 at 2:57
    $\begingroup$ @JedF one part of the answer is that these aren't real-world results - they are modelling outputs. $\endgroup$ – 410 gone Jan 28 '15 at 7:23
