19
Austenite is non magnetic while $\alpha$-ferrite and pearlite are magnetic. (Magnetic properties of pearlite vary as a function of carbon content)
If a strong magnetic field is applied in a particular direction while the steel is being quenched (rather, austenite is being quenched!), would the grain structure change? Is it possible to get superior grain structure and hence tougher steel by application of cyclic magnetic field?
My speculation is that, at the eutectoid point while quenching the steel, as low carbon zone of pearlite has more permeability, that zone should align itself to the strong magnetic field by pushing the carbon in orthogonal direction, so grain boundaries should take a different shape.
Will it actually happen?
  • $\begingroup$ Since you talked about grain boundaries I wonder if you have any idea how to answer this question? It's been one of our longest-lasting unanswered questions and I'd really like to clean up the unanswered queue! $\endgroup$ Jun 22, 2021 at 2:30
16
This will at least depend on the:
  • Rate of Cooling
  • Magnetic field strength
  • Exact composition
The magnetic field will alter the microstructure as you can read in, for example,
For me, it is behind a paywall. But as you can read in the abstract, 30 Tesla will result in, for example, more ferrite. The other paper reveals that for a hyper eutectoid steel, you will have particle like cementite.
I am not aware of any models with which you can make predictions about tensile strength and so on. But, for the question Can we change steel properties by application of magnetic field while quenching?, it is a clear yes. A more complete lookup in the literature would be the next step for models and experiments for a more specific case.
