I want to run a coupled simulation in Ansys - RF heating and deformation of waveguide. Pictures of project layout and settings are here.
I calculated RF fields and surface losses in HFSS; imported them to steady-state thermal, calculated temperature of the waveguide; calculated structure deformation in static structural. Now what is needed is to run this problem until it converges. But for some reason HSFF does not import calculated deformed mesh from static structural. What else should I do to make it import mesh? Can I then use feedback iterator to automatically recalculate this problem?
