I've been attempting this fundamental shear force diagram problem for several days, but can't seem to get the correct result. I'm trying to calculate the shear force diagram in terms of $x$, but I'm unsure about the intensity $w(x)$ of the triangular load distribution between $0m \le x \lt 3m$. I am able to calculate the correct result for the latter section $3m \lt x \le 6m$, so I'm a little confused as to what the correct intensity of the triangular load distribution is and how to calculate the correct shear force using the correct intensity $w(x)$?
Below I've attached the problem and calculated the support reactions, which are $A_y=15kN$ and $B_y=15kN$.
Now, I've attached my free body diagram of the first section between $0m \le x\lt 3m $ and indicated the positive sign convention for this beam.
I then proceeded to find the shear force in terms of $x$ as follows:
$\sum F_y=0:$
$$15-w(x)·x·\frac12 - v_1 = 0 \quad (eq\ 1)$$
Where $w(x)·x·\frac12$ is the area of the triangular load distribution.
This is where I get confused. My understanding of triangular load distribution in terms of the intensity $w(x)$ is that:
$$w(x)=\frac{w_0x}{L}$$
Where $w_0 = 10$ and $L=3$ for this problem.
But substituting these values into the intensity $w(x)$ and back into $(eq\ 1)$ gets me the wrong result of: $$v_1=15-\frac53 x^2$$
After reading multiple textbooks and watching several videos, I finally found out that if the maximum load of a triangular load distribution is at the initial point $x=0$ then the following formula should be applied:
$$w(x)=\frac{w_0x}{L}-w_0$$
I now understand this a bit, but I am wondering where I could get a good explanation as to why?
I'm struggling to find a good explanation as almost every example I've found in textbooks/videos use triangular load distributions that increase from the initial point and not decrease.
However, after utilising this formula, I still get the wrong solution. My working out is as follows:
$\sum F_y=0:$
$$15-\Bigl(w(x)·x·\frac12 \Bigr) - v_1 = 0$$ $$15-\biggl(\Bigl(\frac{10x}{3}-10\Bigr)·x·\frac12 \biggr)- v_1 = 0$$ $$15-\biggl(\Bigl(\frac{10x}{6}-\frac{10}{2}\Bigr)·x\biggr) - v_1 = 0$$ $$15-\biggl(\Bigl(\frac{5x}{3}-5\Bigr)·x \biggr)- v_1 = 0$$ $$15-\frac{5x^2}{3}+5x - v_1 = 0$$ $$\Rightarrow v_1=15-\frac{5x^2}{3}+5x$$
The actual solution is: $$v_1=15+\frac{5x^2}{3}-10x$$
So I'm not sure whether I'm using the correct intensity $w(x)$ and/or whether the triangle area has been correctly calculated using this intensity $w(x)$.
For the second section $3m\le x\lt6m$ I am able to calculate the correct shear force in terms of $x$, this solution is:
$$v_2=-15-\frac{5x^2}{3}+10x$$
Plotting a diagram of the correct shear forces $v_1$ and $v_2$ in terms of $x$ looks the following:
For your reference, this problem (F11.6) can be found in chapter 11 of Statics and Mechanics of Materials (4th Ed. SI edition) by Hibbeler.
I'd appreciate if someone could explain intensity loads for situations similar to above and where I went wrong in my calculations.
Thank you.
Edit:
After reading a few examples, I found that if I calculate the shear force from the left end I am able to get the correct shear force using my initial intensity $w(x)=\frac{w_0x}{L}$ and not the latter intensity $w(x)=\frac{w_0x}{L}-w_0$.
However I'm unsure why I can't calculate this from the right end? Does it have something to do with the left support $A_y=15kN$ creating a discontinuity? If I calculate from the left end am I correct in changing the section's range to $0m \lt x \le 3m$ to not include the left support $A_y$?
$\sum F_y=0:$
$$-\Bigl(w(x)·x·\frac12 \Bigr) + v_1 = 0$$ $$-\biggl(\Bigl(\frac{10}{3}(3-x)\Bigr)·(3-x)·\frac12 \biggr)+ v_1 = 0$$ $$-\biggl(\Bigl(10-\frac{10x}{3}\Bigr)·(3-x)·\frac12 \biggr)+ v_1 = 0$$ $$-\biggl(\bigl(30-10x-10x+\frac{10x^2}{3}\bigr)·\frac12 \biggr)+ v_1 = 0$$ $$-\biggl(\bigl(30-20x+\frac{10x^2}{3}\bigr)·\frac12 \biggr)+ v_1 = 0$$ $$-\bigl(15-10x+\frac{10x^2}{6}\bigr)+ v_1 = 0$$ $$-15+10x-\frac{5x^2}{3}+ v_1 = 0$$
$$\Rightarrow v_1=15+\frac{5x^2}{3}-10x$$
This is the correct solution.
