in the following picture, we should find the viscosity of fluid and we have to have the Area surface of cylinder that is in touch with the fluid. the area surface depends on the bottom of the shape. but i have no idea what's the shape of this cylinder. what is that curve on the bottom of cylinder? does it mean that cylinder is empty inside or what? enter image description here
and the solution of this problem:
  • $\begingroup$ It is labelled « cylinder » so circular ... and the solution shows the view from the top... $\endgroup$
    Apr 8, 2018 at 8:45
  • $\begingroup$ i meant the bottom of cylinder. i know what top of it looks like. the bottom of it may shows that it's empty inside. or maybe it shows it's curved. @SolarMike $\endgroup$
    – user14854
    Apr 8, 2018 at 8:49
There is no info about the shape of that curve in your, ie the book's, question, also, the torque shearing stress is calculated for the gap between the wall and cylinder which is small and much smaller than the gap between the base and the end of the cylinder.
Edit: After a re-read, the question does also say neglect end effects.
  • $\begingroup$ why didn't he calculate the torque shearing stress between base and the end of the cylinder? $\endgroup$
    – user14854
    Apr 8, 2018 at 9:26
  • $\begingroup$ As I put in my answer, the gap is much larger... from the solution given the difference between the larger and smaller radius is used... $\endgroup$
    Apr 8, 2018 at 9:47
