Consider, while building a new machine which has different elements in it. For instance, a machine having a driving assembly, main body, chassis, crucible etc. Then, how would I calculate the center of gravity and how would I know the calculated value is an exact value or Cg value gives a balanced system?
Should I calculate a center of gravity of each element or the whole system?
Suppose I need to calculate the center of gravity of each element, how would I calculate? What are the factors to be considered other than weight and distance from the reference plane?
Any suggestions would be appreciated.
Thank you in advance
