I'm working on a small project where an armature is actuated by a servo via a couple feet of tendon. The servo+tendon needs to be able to pull about 5-10 lbs. There will be springs at the endpoints to allow some flexibility and shock absorption, so I don't need the tendon to incorporate much flexibility of its own. What's the appropriate type of wire to use for the tendon? Should I use Nylon? Or stranded steel? I see a lot of projects using tendons, but I don't see much description of what's the best material to use to avoid snapping and breakage.
1 Answer
I have successfully used a non-stretch polymer known by various names such as Dyneema, GelSpun or Spectra for a similar purpose. It is easily purchased from most fishing supply stores.
The material is extremely strong and non-elastic - some care is needed with termination since it is slippery. Crimps, wire loops and model aircraft clevises are all good terminations.
$\begingroup$ Those brand names are the good stuff for this purpose. The material is also known as UHMW-PE, ultra high molecular weight polyethylene, although the "ultra high" aspect is open for discussion. It's the same stuff, generally speaking that one finds in disposable grocery bags. I can attest to the low stretch aspect as well as the slippery part. I had some 3 mm wide x 1 mm thick rated at 700 pounds breaking strength. $\endgroup$ Mar 24, 2018 at 23:36
