I would like to calculate the spring constant of a frame structure. I thought that I could do it like this:
  1. I apply a point force on the structure: enter image description here
  2. Then I calculate the displacement at that same point: enter image description here
Finnaly, I asume that the material bends within its elastic limit: $k=\frac{F}{\delta_y}$
Question1: Do you agree with this method ?
Question2: If I have a different type of loading, for instance a distributed load, would the spring constant change ?
Yes it would change.
For example same load if applied at quarter span would cause less deflection and a different curve.
Hence bigger K.
basically for the type of loading you display applying the load at center corrolates to smallest K.
  • $\begingroup$ Thank you for your response. If I apply a continous loading (pressure) how can I find the spring index? Do you know? $\endgroup$
    – james
    Mar 25, 2018 at 6:19
  • $\begingroup$ For continius loading say same load as previous one : P if spread over all or part if span, will cause less deflection so the K would be bigger. $\endgroup$
    – kamran
    Mar 25, 2018 at 14:18
  • $\begingroup$ I see. How do you calculate k ? Do you use the equivalent force at applied to the centroid of the continius loading ? $\endgroup$
    – james
    Mar 25, 2018 at 14:27
  • $\begingroup$ I would use something like Hardy- Cross method to quickly calculate the frames stresses and deflctiins. $\endgroup$
    – kamran
    Mar 25, 2018 at 14:30
