This information comes from a design document by the Iowa DOT (US). It might not apply everywhere in the world, but the considerations are probably universal.
For clarity, the amount of banking of a turn is typically called super elevation. At least in the US, this is given as a percentage for roadways.
- The maximum super elevation is 8%.
- The typical high-speed super elevation is 6%.
- The typical urban super elevation is 4%.
The 6% typical super elevation was chosen for:
This reduces the risk of slow moving vehicles sliding down a superelevated roadway during winter conditions.
Speed
Design speed of a highway is not always the same as the posted speed. Drivers have this habit of not following the speed limit. Designers know this and make the roadway safe at these increased speeds as well.
There are only two ways that speed will affect the curve radius. Either:
- The design speed has been set and the geometry limits are based off of that speed.
- The geometry has been set and the design speed is reduced to still provide adequate levels of safety.
Curve Radius
Both the super elevation and design speed are taken into consideration to determine the minimum radius of the curve. These also consider the maximum side friction from both the vehicle's tires and the comfort of the driver. These values are listed in tables for easy look up or in a spreadsheet.
The friction of the vehicle's tires on the road is incredibly variable. It depends on the weather, condition of the road, condition of the tires, etc. Because of this, the values used for design are very conservative.
The other factor controlling curve design is driver comfort. It is surprising how ofter roadway design is controlled by human factors. In this case, the typical driver will be concerned about the amount of horizontal acceleration they are feeling and slow down before the vehicle is in danger of sliding sideways.
Result
So in the end, there are limits on the super elevation of curves that are based on low friction. But this is the controlling factor at low speed and not high speed.
These super elevations are no where near the amount that would be required for no side friction. As you can imagine you never know when there will be a traffic jam on a road because of a wreck. You don't want trucks to tip over toward the center of the curve if they are forced to stop!
The minimum curve radius is then determined based on looking up the information in tables. Often there are other concerns that also might after the curve such as sight distance or vertical curves.
How it works in design
Setting the roadway cross section details (of which super elevation is one) is usually done last in the sequence of design. The sequence usually goes like this:
- Set design details, e.g. design speed, road type, number of lanes, etc.
- Set the horizontal alignment. This would be where the curve radius is set. This is also where geometric constraints are found that might require reducing the design speed.
- Set vertical alignment. This stage can also reveal more geometric constraints.
- Set details of cross section, e.g. super elevation, cross slopes, embankment slopes, ditches, etc.
