Trucks and smaller vehicles with diesel engines run on diesel fuel which looks more or less like kerosene - less flammable than gasoline, low viscosity liquid. However larger diesel engines like this 120 thousand horsepower marine engine have more or less the same design but use fuel oil which looks very different from diesel fuel - much higher viscosity and I'd guess igniting fuel oil at room temperature is a challenge.
How does it happen that engines of the same design use two different fuels? If one of them is superior to the other then why won't they all stick to that superior fuel?
