-1
Image of circuit
The wire is attached to the bottom of each D battery. I already know that I have to put the bottom of the light bulb on the positive side of the battery.
My multimeter looks like this: Multimeter
I'm not sure where to put the testing probes. I don't think this is important, but the wire is made of steel wool.
I hope I can get some help.
  • $\begingroup$ What are you trying to measure. Voltage, or current draw? $\endgroup$ Mar 7, 2018 at 1:15
  • $\begingroup$ vtc as unclear and not an engineering question $\endgroup$
    – agentp
    Mar 7, 2018 at 4:11
  • $\begingroup$ @agentp what is vtc unclear $\endgroup$ Mar 7, 2018 at 13:29
  • $\begingroup$ vote to close, which should be understood as a prompt to the poster to clarify the question. $\endgroup$
    – agentp
    Mar 8, 2018 at 0:56
  • $\begingroup$ why did I try to downvote my own post lol $\endgroup$
    – hpenney2
    Mar 8, 2018 at 2:17
If you trying to measure voltage, connect the black connector probe (Terminal) to COM. Move the rotatory switch 20 DCV. The dot should point to 20 DCV. Then place the black exposed probe to negative and red expose probe to positive button on the battery. You should read somewhere around 1.5V for the D size battery.
Checkout some of the links below. This should help you with your questions.
Reference:
