During world war two the British had plans for an aircraft carrier made of pykrete (a mixture of 14% sawdust or wood pulp and 86% ice.) the idea was to have a refrigeration system to stop the ice from melting however I can't help but think that since the temperature would still be very near to the melting temperature of ice that creep would have been a problem. does anyone have any knowledge about the properties of ice regarding creep?
1 Answer
Edit: see here for a contemporaneous study of this exact question: Perutz, "A description of the iceburg aircraft carrier," Journal of Glaciology (1947).
The dominant creep mode and rate can be read from a deformation mechanism map. Shouji and Higashi, in "A deformation mechanism map for ice", Journal of Glaciology (1978) included the following map for ice with a 2 mm grain size, based on experimental data from studies in the 1960s and 1970s:
Michael Ashby, who contributed substantially to developing and popularizing these types of maps, performed a case study on Antarctic ice that included the following map for ice with a grain size of 10 mm:
The trends shown in these maps emphasize the importance of ensuring low stresses if ice is to be used as an engineering material near its melting point without substantial creep deformation.
Note that these diagrams are for pure ice; the presence of a binder can be expected to alter the dominant failure model and strain rate. I haven't found a corresponding map for pykrete. However, the first link (given in the edit comment) suggests that the relevant parameters are a normal stress of approximately 70 MPa—presumably corresponding to a shear stress of approximately 35 MPa—and a temperature of -15°C. It's also emphasized that the addition of the wood pulp/sawdust can strongly suppress long-term ice creep. The other links here provide an introduction for the various modes of creep that apply and a general idea of the strain rates that can be expected.
$\begingroup$ You have the data for an answer, but you don't actually answer the question asked in the title. (You did answer the question in the last line of the question text though...) $\endgroup$– hazzey ♦Mar 2, 2018 at 19:07
$\begingroup$ I've edited my comment to link to a study that addresses creep in pykrete. $\endgroup$ Mar 2, 2018 at 19:36
