i'm trying to connect a D-cut shaft to a plate for transmission of torque
This is the motor that i am using with a 'diameter' of 4.5+/-.1mm
My first question is whether I can use 5mm circular universal mounting hub like this to do so?
Secondly, i have access to a a laser printer. Would you recommend making a mounting hub similar to the one shown above but with a D-Cut hole? It has a precision of .2mm, so along with the uncertainty in the shaft of 0.1mm, I guess I would have to make the 'hole' 4.8mm. Would this potential difference in size mean that the torque may not be transmitted efficiently?
