I have purchased these copper heat-pipes; however, I am wondering how to bend them without kinking them or cutting them open due to pressure on weak points/bends.
These are flat copper heat pipes, so I can't use a pipe bender; however, these are sold specifically to be bent, according to descriptions, so I was wondering if anyone here has any experience or tips for bending these flat copper heat pipes.
To be a little more specific, I want to make a 90 degree bend in the middle of the copper heat pipe, without making kinks (which degrade performance).
Furthermore, would wrapping copper foil around the heat pipes allow for greater thermal dissipation? Apparently some computer modders have seen success; however, I thought it would be appropriate to ask opinions here as I will try to wrap copper foil set in place by thermal paste to the heat pipes.
20
  • $\begingroup$ So, follow the instructions about bending that surely came with the things - or did these "fall off the back of a lorry"? $\endgroup$
    Commented Feb 22, 2018 at 16:53
  • $\begingroup$ @SolarMike they did not come with instructions, just purchased them off some knock off website $\endgroup$
    – user15044
    Commented Feb 22, 2018 at 17:04
  • $\begingroup$ Get your blow-torch out and heat them up where you want to bend them. $\endgroup$
    – Trevor_G
    Commented Feb 22, 2018 at 17:06
  • 3
    $\begingroup$ Wear eye protection when experimenting... Next time buy from a reputable supplier so you get instructions - it could save your life... $\endgroup$
    Commented Feb 22, 2018 at 17:37
    $\begingroup$ fwiw these things appear to be meant to be bent flat-wise aliexpress.com/item/…. If you kink it at all you will pinch off the working fluid and it wont work. $\endgroup$
    – agentp
    Commented Feb 23, 2018 at 2:04
Copper is notoriouos for hardening and breaking under bending or hammering it, or working it any other way. To keep it soft and flexible, you have to anneal it often while working on it. It also bends easier and breaks less soon when you bend it while it's hot. You can heat it with the torch, but you're right about exploding it, getting it too hot may get the pressure too high, and the pipe may pop. Especially since it's filled with some kind of chemical, that may be dangerous. So at least wear goggles and gloves, but rather a full face mask and clothes that cover your arms. Since the pipe is so small, and probably filled with little fluid and mostly gas, i think it will rather 'pop' than explode, but still it can be dangerous.
To bend it you can cut three disks from eg. aluminium or any metal. The middle one will have the radius of the inner radius of the pipe bending, the two outer disks will have that radius, plus the width of the pipe. They will keep it from twisting while you bend it. To minimise the risk of breaking the pipe, keep the radius of your bend as large as possible. Heat the pipe and start making a small bend of a few degrees, reheat it again and bend it a few degrees further, repeat until bent enough.
You're right about your foil thing. Heat pipes are the most effective thing in transporting heat, not dissipating. They just relocate the heat from the source to somewhere else. You can't really get rid of any heat with just heat pipes. That's what you need a heatsink for. A heatsink is meant to dissipate heat. So it has to have a large surface, preferably close to the source. Heat pipes are used in laptops since it's not possible to put the heatsink onto the processor. Thus, a heat pipe is used to transport the heat to the side of the laptop, where the heatsink is located. Thermal paste is used for a proper heat conduction between heatsink and heatpipe or source. Keep the paste layer as thin as possible.
Copper is the best material for conducting heat, but aluminium is often used since it's cheaper. I'd rather buy a good heatsink than try and craft it yourself. It probably won't be as effective. When searching for a heatsink, look for the right C/W rating. It basically means how hot it will get when dissipating a certain amount of heat.
5C/W means it will get 5C hotter for every Watt of power it has to dissipate. When you know the temperature you allow, and the power you have to dissipate, you know how much C/W you need for a heatsink. So lower is better. You can put a fan on the heatsink to make it dramatically more effective. C/W rating is mostly for still air.
  • $\begingroup$ Thank you very much Bart! So, in your eyes, wrapping copper foil as I explained with thermal paste is a good idea? Also, what's the purpose of selling these copper pipes if they can't be bent easily at all? $\endgroup$
    – user15044
    Commented Feb 22, 2018 at 18:57
  • $\begingroup$ @OmarSumadi It's better certainly than nothing, but just copper foil isn't ideal for releasing the heat into the air. Study the design of radiators to get an idea for an optimal design. As others already implied, it could be that this is a batch that couldn't be sold for whatever reason, and thus they dump it onto the public market. Just like all the stuff you can buy on AliExpress etc. You can't bend it easily, but OEM manufacturers can. They have special tools and machines. And it's also possible for them to fill the pipe after bending. $\endgroup$
    – Bart
    Commented Feb 22, 2018 at 19:52
  • $\begingroup$ The working fluid in copper heat pipes is most likely water. Especially if they are meant for electronics cooling (with operating temps between 20-150°C). $\endgroup$ Commented Feb 23, 2018 at 10:53
  • $\begingroup$ @ratchetfreak Could be, but nothing is know about the heat pipes in question. I've hear them being filled with ammonium or other substances also. $\endgroup$
    – Bart
    Commented Feb 23, 2018 at 12:15
  • $\begingroup$ I think it would probably not explode if it fails, just rupture at an end or along an edge. But I am quite sure that the result is not a 'pop' in any way. It is a sharp and loud bang. Very very loud. The pressure energy that was enough to rupture a metal pipe is converted into a bang, roughly 100% of it. In the beginning of the expanding gas bubble, around the rupture, I think it is even expanding supersonic, not sure about that, And because of the small spacial volume of gas, you would not be inside the supersonic bubble. $\endgroup$ Commented Nov 28, 2019 at 4:54
