I have a simple, practical engineering question.
I'm trying to design a hot water circulation system with a constant flow rate of 1.3 L/min. I'm having trouble finding any pumps that will do the job at the temperature (80-100C) for a reasonable cost.
Essentially, I'm trying to Development of a Consistent and Reproducible Porcine Scald Burn Model
Does anyone know:
  1. Where to search for for reliable, inexpensive, high-temperature water pumps? I tried McMaster Carr, but they didn't have anything that fit the bill.
  2. Another way to adjust the flow rate? I thought a nozzle might work, but I'm worrying about too much back pressure damaging the pump, or worse, that a restricted area wouldn't even reduce the flow (RTT)?
    $\begingroup$ This looks like a resource-hunting/shopping question. Such questions are prone to becoming out-dated, and are therefore considered off-topic for this site. $\endgroup$ – Wasabi Feb 12 '18 at 23:49
  • $\begingroup$ @Wasabi Sorry. Could you point me to an appropriate place to ask this question? $\endgroup$ – BJC Feb 13 '18 at 0:26
  • $\begingroup$ Grundfoss also make flow controllers as well as pumps... $\endgroup$ – Solar Mike Feb 13 '18 at 4:10
Many commercial hot water recirculation pumps will do that. Just grabbed one at random - Grundfoss Alpha1 15 40 130.
I couldn't fetch the page after I ran their calculator. I used temp of 99C and head of 2m. 100C doesn't work in their calculator. Click link then click "view in product center", and fill in form. ALPHA1 circulator pump - heating, cooling, hot water
You also have to edit settings for 60hz.
