I have to design a model of a domestic boiler. I represent the boiler as a heat exchanger (HEX1), as shown in the figure. In many articles I have found that it is schematized with this equation:
$$ M C \frac{\text{dT}_{10}}{\text{dt}}=\text{c m$\_$dot} \left(\text{Ti}-T_{10}\right)-Q $$
where $M C$ is the thermal capacity of the boiler, and $Q$ is the heat product by the burner.
My question is: why there is $\frac{\text{dT}_{10}}{dt}$ at the left hand side of the equation? Why not $\frac{d\frac{\text{T}_{10} + \text{T}_{i}}{2}}{dt}$ or $ \frac{\text{dT}_{i}}{dt}$?
Thank you!
Update: Connor thank you for the answer. However I don't understand:
And finally, the rate at which heat is stored within the control volume is proportional to the rate of change of temperature of the exchanger: $$Q_{stored} = M C \frac{dT_{10}}{dt}$$
Why the temperature is $T_{10}$? I have found that a possible answer is ralated to the so colled "well-mixed conditions", infact in a article:
"the time derivative of the total energy in the mth block is calculated on the basis of the well-mixed condition"
Is there a better explanation of the well-mixed condition?
