I want to have a star dot above each bar chart. I don't know how to present that index. Please anyone help me to resolve this problem,
  • $\begingroup$ Create a dummy data set and set its point as a star dot. Stack overflow may be better for excel questions as it is not statistics really. $\endgroup$
    Commented Jan 31, 2018 at 8:41
  • $\begingroup$ What kind of dummy data should be added? And how to set a star dot? I am really still fuzzy in this matter, if you dont mind to give me more explanation.. $\endgroup$ Commented Jan 31, 2018 at 8:45
  • $\begingroup$ Use the add data function, x values you already have, y values can be zero or 1 or whatever value to get the stardot where you need it - but make the data line blank so it is not seen. $\endgroup$
    Commented Jan 31, 2018 at 8:59
  • $\begingroup$ Another trick is to make a second chart which is transparent except for the data and lay it on top of the first - did that once - what looked like a single chart was actually six - the people trying to steal the work were tearing thier hair out as they couldn’t get their chart to work :) :) $\endgroup$
    Commented Feb 1, 2018 at 6:10
  • $\begingroup$ Thank you very much Solar mike!! I really appreciate it!! $\endgroup$ Commented Feb 1, 2018 at 6:45
Quite seriously: Friend Don't Let Friends Use Excel. Learn to use Matlab/Octave, or python, or R, or just plain Gnuplot.
No matter what tool you use, since "significance" is a separate variable, you need to convert your collection of "*" , "**" etc to numeric values and plot the desired symbols at the matching category locations.
  • $\begingroup$ Thank you Carl Witthoft.. It is solved already.. thank you alot, I really appreciate it $\endgroup$ Commented Feb 1, 2018 at 6:46
    $\begingroup$ Or the up-and-coming Julia language with some world-class scientific applications here. $\endgroup$
    – AsymLabs
    Commented Feb 1, 2018 at 20:17
