I'm simulating the flow in a capillary with a sudden expansion. The small capillary has a diamater of 250 µm. The big capillar has a diamater of 1000 µm. My flow rate ist $ 1\frac{ml}{min} $. Using standard properties of water I have a Reynolds number of 85 in my small pipe. For my mesh I choose one similar to this case: https://openfoamwiki.net/index.php/Sig_Turbulence_/_Dellenback_Abrupt_Expansion. I am using a low-Re mesh. I simulated it laminar first, but it seems unphysical to me, because I couldn't see any vortex, but because of the high expansion ratio one would expect a vortex after the sudden diameter change. Now I'm using k-omega-SST and getting similar results (no vortex at all). My simulation is converging well.
Do I have to use a special turbulence model for these situation? Or am I wrong in expecting a vortex in this situation?
Best Regards, Gesetzt
