-3
I'd like a simple explanation of the function of by passenter image description here,
here is an image of the project am working on and if it can help clarify.
  • $\begingroup$ Please provide more context - where have you seen the term? What project are you working on which might require a bypass? Are you thinking of a valve? The more information you give, the higher the quality of answer that you will receive. $\endgroup$ Jan 29 '18 at 14:49
  • $\begingroup$ - The project is a skid count( measurement ) of Gasoil. and the by pass coutains a valve, therese like two parallel pipe line with the same instrument and valves and theres the link ( the by pass ) between them that contains a valve i hope i explained like u asked $\endgroup$
    – Azed S
    Jan 29 '18 at 14:51
“By-pass” generally means to take an alternative path or route around something, so could be a village or a valve or a flow meter.
Sometimes meters have a by-pass arrangement with 3 valves so that they can be replaced without stopping the flow.
