I know how to solve it by moment line methode but i want to use singularity function here and i'm very confused. My strategy consist of writing the correspond singularity function for each element but i have absolutely no clue how can i write the right singularity function for the inverse ramp distributed load at the right side? enter image description here
Are you familiar with the Dirac delta function, Heaviside step function and the Ramp function?
You could use Laplace Transforms together with those three handy functions:
Dirac Delta function
$$\delta(x)= \left\{\begin{array}{l}+\infty\qquad&x=0\\0&x\neq0\end{array}\right. $$ The Dirac Delta function is equal to infinity, at $x=0$, and $0$ everywhere else. Respectively $\delta(x-a)=+\infty$ if $x=a$.
With the Euler-Bernoulli beam theory, where $$ EI\frac{d^4w}{dx^4}=q(x) $$ a static interpretation of the Dirac function is, that a point load $Q$ at point a represents a distributed load with infinite density, thus can be written as $q(x)=Q\cdot \delta(a-x)$
The step function is the integral of the Dirac Delta function $$ H(x)=\int_{-\infty}^x\delta(s)ds $$ or $$ H(x)= \left\{\begin{array}{l}1\qquad&x\geq0\\0&x<0\end{array}\right. $$ Thus, a distributen load, with magniuted $q$, between $x=a$ and $x=b$ can be written as $q(x)=q\left[ H(x-a)-H(x-b) \right]$
Ramp function
The ramp function again is the integral of the Heaviside function. $$ R(x)= \left\{\begin{array}{l}x\qquad&x\geq0\\0&x<0\end{array}\right. $$ Thus, a distributied load , starting at $x=a$, with a slope $m$ can be written as $ q(x)=m\cdot R(x-a) $
The following distributed load, for example: enter image description here
This load can be written as: $$ q(x)=\frac{q}{b-a}\left[R(x-a)-R(x-b)\right]-\frac{q}{d-c}\left[R(x-c)-R(x-d)\right] $$ please see attached file for the derivation
Further explanation of the Dirac Delta function
Take, for example the point force $Q$. That force can be approximated by a distributed load $Q=q\cdot dx$, therefore $q=\frac{Q}{dx}.$ Now, as a point load acts on an interval $dx\to0$, we can say $\lim_{dx\to0} q=+\infty$
This is also represented, if you look at a shear force diagram. We know, that $V'(X)=q(x)$, and we know that a point load $Q$ (external force or support) at point $a$ causes a "jump" in the shear force diagram, according to its magnitude, this can be represented by the Heaviside function. $V=Q\cdot H(x-a)$, now $$V'(x)=q(x)=(Q\cdot H(x-a))'=Q\cdot H'(x-a)$$ As explained above, the derivative of the Heaviside function is the Dirac delta function, therefore $$ q(x)=Q\cdot \delta(x-a) $$
  • $\begingroup$ Thanks for your elegant answer. Could you please explain more about the static interpretation of Dirac function ? the rest is clear. $\endgroup$
    – user14407
    Jan 23, 2018 at 21:16
    $\begingroup$ I added some further interpretation/explanation to the Dirac Delta function at the end of my answer, I hope my explanation is comprehensible. $\endgroup$
    – Andrew
    Jan 24, 2018 at 11:28
