Lets pretend I designed a plastic Lunchbox, like the ones pictured below in solid-works.
this
What processes or options are involved in obtaining a physical sample of my design?
    $\begingroup$ Are you asking about the possibilities to manufacture such boxes? This highly depends on the amount of pieces you want to have. For just one sample, try rapid prototyping methods (additive manufacturing). $\endgroup$ – Robin Jan 14 '18 at 9:29
  • $\begingroup$ What are the requirements that you need from your prototype? Is it just to get an idea for the size/shape of the item? (3D print it), is it so you can demonstrate your product at a trade show? (3D print it, sand it, paint it), is it so you can carry out functional testing, or sell small batches? (3D print a master, sand it, make a mould, and vacuum cast it), or is it so you can sell large batches? (injection mould it) $\endgroup$ – Jonathan R Swift Jan 14 '18 at 13:19
Without additional information regarding your design, the answer is difficult and has to cover multiple aspects. As noted in the comments, injection molding is expensive to set up, especially to produce one unit. You have not indicated that your design requires this method.
If your design lends itself to 3D printing, there are online 3D printing services such as Shapeways and others which will take your design and return to you a model created in the material of your choice.
Even a 3D printed design such as the lunch box, which would have fragile walls due to lack of thickness, could be created if you did not require structural strength. The same model could be used as the master of a home-made mold which would then allow for resin casting at relatively low cost.
If the design does not lend itself to 3D printing, there are fabrication services such as emachineshop.com but they would require a different source reference, likely in DXF format. SolidWorks can generate such documents, to facilitate the construction/fabrication of your work.
In all cases, you would have each component created separately and assembled after creation. An exception to this is SLS 3D printing, in which the nylon powder used to create the part also serves as the support and separator material. Moving parts can be created in one print, fully assembled. SLS 3D printing is very expensive compared to other forms of additive manufacturing.
On the reverse side of the coin is machining. Your design could be machined on a CNC milling center. This process would require a block of material slightly larger than your design and all portions of the block that are not part of the design are carved away by high speed cutters of various shapes. Because this process requires a large block of raw material and removes so much, it is also quite expensive. Solidworks is capable of creating the files necessary for producing an item in this manner.
  • $\begingroup$ Your design is intended for mass production in some soft plastic. Your prototype should evaluate the properties of the catch and the assembly of the handle and the hinge. It is difficult to match the properties of the intended plastic with SLS 3D printing. And the subtraction milling process is difficult with thin wall soft plastics - how do you hold it? So I think that you'll need jump into the injection molding process and start talking with these manufacturers. $\endgroup$ – D Duck Nov 14 '20 at 12:44
