I'm working on a project where we are trying to prototype a whistle that works at the lowest possible air pressure and still produce an audible sound.
Any suggestions on whistle type? and any additional factors or insight that might help, would be appreciated.
Assume, Open air 72 degree Fahrenheit environment using very consistent airflow of regular 72 degree Fahrenheit air.
12
  • $\begingroup$ See this : engineering.stackexchange.com/q/18784/10902 $\endgroup$
    Jan 10, 2018 at 19:35
  • $\begingroup$ Air pressure in a vacuum? Is pressure constant regardless of volume used? Is it literally air? What temperature? $\endgroup$
    – paparazzo
    Jan 10, 2018 at 20:05
    $\begingroup$ Where do you get 27mph wind would apply a pressure of 2 pounds per square feet? I do not have the rep to down vote yet. $\endgroup$
    – paparazzo
    Jan 10, 2018 at 22:35
    $\begingroup$ Round and round the mulberry bush.... $\endgroup$
    Jan 11, 2018 at 0:59
    $\begingroup$ I see you are asking a lot of questions about whistles. It seems like you're creating an XY-problem and you want the whistle to do something very specific. If you can tell us what you want to do with the whistle, maybe we can be of better assistance. $\endgroup$
    – ChP
    Jan 11, 2018 at 11:06
Native american flutes from: Intraoral Pressure in Ethnic Wind Instruments Clinton F. Goss.
This study measured intraoral pressure when playing six classes of ethnic wind instruments (N = 149): Native American flutes (n = 71) and smaller samples of ethnic duct flutes, reed instruments, reedpipes, overtone whistles, and overtone flutes.
  • $\begingroup$ @agentp Collect 1000 rep, so you will be able to edit anything. I unfortunately mis-clicked your review (I should have rejected it), but you can still fix it by removing your unneeded comment, and fixing some other things in the post (convert the URL to a link, capital letters, and so on). If you really want to insert something invisible into a post, you can insert a html comment (<!-- comment -->). But it is unneeded in this case, because the post needs many fixes besides yours, too. $\endgroup$
    – peterh
    Jan 11, 2018 at 5:47
  • $\begingroup$ @peterh glad to fix if someone will clear the pending edit review. $\endgroup$
    – agentp
    Jan 11, 2018 at 12:35
  • $\begingroup$ @agentp O.k.! By improving an edit can I make it accepted on the spot. :-) Tyvm :-) $\endgroup$
    – peterh
    Jan 11, 2018 at 12:56
