From my understanding, the more surface area the flow passes, the more drag happens due to skin friction.
An example of this is the new Ford GT, which has a converging cockpit and separated side body panels. I did some research and the answer I found is related to decreasing the frontal area of the vehicle, but when I compare it with the increase of the surface area it's almost double the area of similar cars.
Image source: ford.com
