I have a heat pump which moves heat from outside to inside. I also have a solar heating array that collects radiant heat from the sun. Given that my goal is to heat the inside (with minimal energy consumption from the heat pump), my question is: Is it better to heat the air inside with the solar array or to heat the heat pump's evaporator outside?
Breaking this down, it's a question of whether it's better to use these sources in parallel or in series. In parallel, the solar array heats the inside directly and the heat pump heats the inside directly. In series, the solar array heats the evaporator and the heat pump heats the inside directly.
Some other relevant details, the evaporator exchanges heat by convection and is limited to a minimum temperature of 0°C. This is because any colder and you risk freezing the convector, thus stopping convection. The environment can get as low as 3°C at night, meaning heat is exchanged across a minimum of a 3°C difference.
Assumptions for this, the heat pump can move 5kW of heat across a 12.8°C difference (8.3-21.1°C), consuming 2kW. The indoor heat loss is (let's say) 5kW for a 15°C temperature difference (5-20°C). The solar array acts as a heat reservoir with 10kWh stored at 40°C (5°C to 40°C). Finally, let's assume the heating time is 10 hours.
